| I did a plenum pull after 2wks of getting my car because there was smoke coming out from the passenger side, behind the balance tube. Changed all the parts ( gaskets, pcv valves, hoses ) now Im almost done putting everything back on and I think I found the problem (maybe) as I see this hose under the exhaust valve cover thats going down towards the turbo..maybe its worn off/cracked or something If someone knows what Im talking about could you tell me if its the water or oil cooling hose? and is it a regular hose that I could get from Napa? or HAS to be nissan?
